Home Forums Products Stompboxes H90 loud hiss and hum Reply To: H90 loud hiss and hum
#173931
Bert Sleeckx
    Hello Joe,thanks for your responce.
    The H90 is in Global Kill dry mode, the amps loop has a dry/wet balance but 100% is
    still parallel! It’s not possible to make it serial.
    There is a 50Hz noise when the H90 (in dual mode) is connected like this:
    Guitar->H90 input1
    H 90 output1->Duotone  H&K input
    DuotoneH&K send->H90 input3
    H90 output3->DuotoneH&K return
    In the amps clean mode it’s not a problem.
    In overdrive mode it’s a lot worse,
    and in boost mode it’s almost unusable.
    When I connect usb then it’s only usable in clean mode! I’ve made recordings off the noise.
    But when I put the H90 only in the parallel loop there’s no 50Hz noise, and almost no usb noise, but then I can’t use Whammy, Octaver, Wah, Weedwacker…….
