Home Forums Products Stompboxes Weird changing trails between presets (With delay) Reply To: Weird changing trails between presets (With delay)
#173973
    Welcome to the community! Thanks for this information. I just copied your Programs and I can reproduce the issue.
    It seems that this only happens when Tempo Sync is on for Head Space. If you turn Tempo Sync off (press the Presets and Parameters buttons while the Head Space Preset is highlighted) then you should find that the delay tails ring out without changing the pitch when a new Program is loaded.
    Note that you can still use tap tempo for Head Space with Tempo Sync off. See “Preset Tap Tempo” –  https://cdn.eventideaudio.com/manuals/h90/1.5.2/content/play-modes/perform.html#tap-tempo
    I would suggest using Head Space with Tempo Sync off for the time being and for your live recording if possible.
    We’re looking into a fix for this. Thanks for reporting the issue.
