Home › Forums › Products › Stompboxes › Need help with Delay settings for this song › Reply To: Need help with Delay settings for this song
This should not require both presets A and B.
It seems to me that in preset A using delay A only is a mistake. I suspect your preset B is correct and is doing all the work here. If you mute preset A there is prolly no difference. Also, I’m hearing the initial “hit” and two softer repeats. So I suggest you try wet mix at less than 50 percent and using preset B only.
Also, there are many ways to skin this simple cat. Using Digital Delay is fine, but when I hear just one, two, or three repeats I always think of a multitap delay. Ultratap is my favorite. The way multitaps work, you specify the total length of time and the number of repeats. Here it might be 560 ms and 2 repeats. Sometimes there is a repeat parameter and here that would be zero.
That’s a nice song (Sugar).
