Home Forums Products Eurorack Modules Midi Note map problem that’s strange Reply To: Midi Note map problem that’s strange
#174304
GMB
    OK – what’s wrong has nothing to do with Misha!
    For some reason the Erae touch is moving the notes I’ve assigned to the misha like pads (I created this template) DOWN two octaves.
    The Erae touch has an octave selector (the +/- buttons on the left) but they are not working with the custom buttons I drew.   I think this is a bug or they need to add a toggle so buttons can be exactly the note# you want or relative to the selected octave.
    Using a regular keyboard I was able to determine that the midi notes I’m trying to use are the right ones.  And temporarily while I figure this out, I was also able to compensate for the offset and got it working.
    Next up I need to program some buttons to use CC’s to change the scale and other things.
