Home Forums Products Stompboxes H90 looper mix param Reply To: H90 looper mix param
#174406
    Yes, the 3 behaviors you have outlined are intentional for how the Looper’s mix parameter works.
    If you turn Kill Dry on, this will remove the dry signal from the looper entirely. You will only hear the looped audio and the mix parameter will act as a level control for the loop.
