Home Forums Products Stompboxes H90: How to use Expression Pedal as Volume Pedal Reply To: H90: How to use Expression Pedal as Volume Pedal
#174598
    Sorry for the late response, I didn’t see your initial post.
    As you have found, there is currently no way to map the range on global parameters. If you need a specific range for the output gain, you’ll need to map it for each Program.
    We may look into a way to improve this in a future update. Sorry for the inconvenience.
