Home Forums Products Stompboxes MicroPitch Pedal – Exact Values with EDM Reply To: MicroPitch Pedal – Exact Values with EDM
#174619
udi9
    Sure, you can download it here.
    To set a specific delay time:
    1. Make sure you’re in Tempo Mode.
    2. Type the desired time (in milliseconds) in cell K1 – for example 125ms.
    3. Choose one of the rows – for example row 17
    4. Set the Delay (A or B) knob to the corresponding MIDI value of the row (column A) – in this case 15
    5. Set the pedal’s tempo to the value in column G – in this case 60
    Notes:
    * It doesn’t really matter which row you choose, as a long as the tempo in column G is in the allowed range of the pedal.
    * I can’t remember atm if the pedal allows decimal BPM values, so preferably, choose a row with a whole number in column G when possible.
    * You can also type in a tempo BPM in cell I1 (I mistyped J1 in my previous post), and column F will display the delay times that match the MIDI values in column A.
