Home Forums Products Stompboxes H90: Increase length of sustained trails between presets Reply To: H90: Increase length of sustained trails between presets
#175075
    That’s going to be a tricky one, BenG, for a number of reasons.  HotSawz does have Gate Sustain, but you can modulate the levels for up to 6 seconds (Attack + Decay).  It also has an envelope follower, but it’s going to ‘drop off’ when your input reaches a certain threshold.
    Some algorithms (especially reverbs) allow you to freeze, but ‘indefinitely’ often depends on the structure, modulation, EQ …  You can easily create pads using H90 reverbs, though.
    The newer pitch algorithms dedicate a Performance Switch to FREEZE, but I honestly don’t know how that might hold up through a Preset change.
    Just speculation, I don’t know if this would work.  I’m thinking along the lines of 2 two-part Programs.  Preset A being the part you change in both Programs, in series with Preset B being the same for both Programs.
    Something would have to ‘excite’ Preset B through the Program change.  As a start, I would try a reverb with an INF decay.  It might ‘survive’ a Preset switch; it might not.
    I built an ‘infinite sustain’ Program out of two reverbs, quite a while back.  I’ll see how that reacts in the scenario you’re describing.
