Home Forums Products Rackmount H9000 used as an audio interface and effects processor simultaneously? Reply To: H9000 used as an audio interface and effects processor simultaneously?
#175657
Puppeteer
    Yes, this is easy to acheive.  If you don’t want FX on the stereo input, just wire it directly to the AES output.
    Set the Digital Audio Mode to AES XLR
    Clock
    Next, in the Direct I/O window connect Analog 1 and 2 to AES3/XLR 1 and 2.
    Connections
    You could also do the routing in an FX buss if you wanted to, but this is the simplest way to do it.
