Home Forums Products Rackmount H9000 used as an audio interface and effects processor simultaneously? Reply To: H9000 used as an audio interface and effects processor simultaneously?
#175705
You can use any of the I/O on the H9000 simultaneously, but the XLR inputs are shared with channels 1-2 on the analog DSUB input.
You could use analog channels 1-2 > AES output, while also using analog channels 3-4, 5-6, 7-8 with the patchbay.
Or, you may find an alternative solution. Can you provide some more details about your setup? Which console exactly are you using? And the PCie card uses the AES/EBU DSUB connector?
