Home Forums Products Rackmount H8000 how to create monolithic patch? Reply To: H8000 how to create monolithic patch?
#175804
tonyshred
    I’d like to know how to do this as well. Basically how to send an e.g. Long Delay preset in A > Reverb preset in B, or combine those into one preset. Any help is much appreciated.
    You can use vsig to combine several algorithms into one algorithm, if it gets too big it will go into monolithic by itself. But there are many muliteffect algorithms already in the box so without knowing what you try to achieve it’s probably there already. But if you want to load algorithms in both DSP’s simultaneously I think you need to do that via MIDI.
    I am pretty sure those are in the box already.
