Home Forums Products Stompboxes H90 Bug Report: Audible room size changes between parameter steps steps Reply To: H90 Bug Report: Audible room size changes between parameter steps steps
#175875
    I wasn’t sure if you were using H90 Control, or the Quick Knob encoder on the H90 itself.  So I tried both – with Size mapped to the Preset HotKnob as well – in both the Blackhole and Hall algorithms.
    I’m not seeing the parameter / displayed value lagging anything, anywhere.  Yes, the sound of the reverb will shift with each incremental value.
    You’re changing the virtual dimensions of the room (or enclosed space).  Size adjusts the early reflections, material of the “walls”, frequency response, etc.  Move it toward a smaller Size, and there’s an apparent pitch shift upwards.  Toward a larger Size, the perceived pitch goes down.
    It’s a momentary “bend” when you move slowly, then the Size settles down quickly.  A rapid change in Size pitches further, and takes longer to recover back to its new Size.
    If you’re not referring to what I described above, please add some more details about your change of tone that might shed more light on it.
    I can tell you that reproducibiltiy in sound design hasn’t been a concern of mine.  I’ve seen a few unrelated instances where you can’t dial in an exacting value, or a directly typed value ‘”rounds” up or down.  But’s that’s in parameters with hundreds of possible positions, never a 0-100 range.
