Home Forums Products Plug-Ins Split EQ Latency Reply To: Split EQ Latency
#175899
foxes
    I’ve just bought the Split EQ at is TOTALLY unusable because if the latency it introduces. I’m using it in Pro Tools 2023.6 with delay compensation on and when I put the plugin on a channel everything goes out of time which gets worse if I turn the delay compensation off!
    And I’ve read here on this thread that in order for the Split EQ to process the transient and tonal parts of a signal it introduces some latency but this is beyond usable and I’ve wasted my money if it can only be used on the master bus!
    Eventide are you working on update to get the latency down to a practical usable level?
