Home › Forums › Products › Rackmount › H9000 used as an audio interface and effects processor simultaneously? › Reply To: H9000 used as an audio interface and effects processor simultaneously?
Follow up on this after more research.
From reading the H9000 with the Optional cards can act as a digital bridge between various digital protocols?
I have 2 independent sets of converters that ideally would pass signal digitally through the Eventide as a bridge. I see optional cards are limited to 32 channels at 96k. This would work for me.
Converter set 1: Antelope Orion 4: 64 analog I/O to the console. Will primarily use for D/A. Thunderbolt to Mac Studio port connection. Madi digital connection. Orion can transmit both analog and digital simultaneously. (Mac Studio).
Converter set 2: IZ Radar Ultranquist: 16 I/O analog to the “print” mix tracks/rig. Dante connection only. (Mac Mini).
Is it possible to pass the converter digital signals back and forth through the H9000 bridge?
