Home › Forums › Products › Stompboxes › H90 pads for soloing › Reply To: H90 pads for soloing
#176343
apalazzolo
    The UltraTap algorithm has a factory preset called UltraSwell that is a great starting point for pads.  You can control that with an expression pedal for smoother fade-out.  Or you can put reverb after it to smooth out the release.   Perhaps you can track that into the looper and then play over that by swapping in another preset to play along with the loop?  Good luck!
