Home Forums Products Stompboxes White noise Reply To: White noise
#176381
I can’t take any credit for that ReVerbed Space Program; that’s all the excellent programming skills of P/S contributor @rck.
And I’m finding the theory posted above by @wewagner to have merit.  Rec Drive set low seems to contribute most to the noise issue.  It is somewhat counterintuitive to crank up a distortion parameter, unless you consider automatic volume compensation at play among the many controls here.  Certainly a better compromise than dropping down the wet Mix, or eliminating / reducing Levels on some of the Heads.
That theory is still a work-in-progress for me here, but I’m working on a HeadSpace / PolySynth Program that’s showing some real promise.
