Home › Forums › Products › Stompboxes › Polysynth Questions › Reply To: Polysynth Questions
December 2, 2023 at 2:55 pm
#176449
- Curious, are you using the LFO Dest set to Detune, with a positive or negative LFO Amount, or just the Detune parameter itself? Some combination of the above?
- Without knowing the above, I can suggest to start by using one or the other: Detune itself, or LFO Dest – Detune with LFO Amount minimal. Set whatever you’re not using at the moment to zero.
- Hmm, I don’t find PolySynth to be dropping off the cliff like HotSawz. The filter envelope follower is a joy to use on string decay. If Cutoff / Resonance is bright, high & sustaining, have you tried the Freeze & Freeze Rel combinations?
- Yeah, I think that’s a function of the badass filter. You can easily add up modulations and get that filter popping. My only suggestions there are to back off the Cutoff / Resonance some, try reversing pos & neg, or tone down the modulation parameter amounts.
