Home › Forums › Products › Stompboxes › H90 Modulate „Insert Mix“ › Reply To: H90 Modulate „Insert Mix“
December 4, 2023 at 9:43 am
#176484
HCAL
Hello and thank you for your fast reply.
As said; that would be very useful, as one can “keep” more of the beautiful H90 algos in the mix by adding external pedals for duties. The idea is to bring the bring the insert in and out and let the H90 Algos dynamically react to this change. So a full “instrumental FX” integration so to speak.
Yes, an synced LFO of some sort but with control over its VCA or Depth , so similarly, being able to bring the Modulation in and out with expressions and Midi.
The whole idea behind of what im writing is to open the Pedal up for external sequencing.
