Home Forums Products Rackmount Clocking of Eclipse and H8000 Reply To: Clocking of Eclipse and H8000
#176508
tsternfeld
That’s true-ish (with caveats): In a large, many-device setup (where some devices may be more accurate at deriving clocks than others) you may be able to get more tightly coordinated clocks more reliably and with less jitter by using a clock generator and WC to distribute the same clock to all of your devices (rather than using the carrier clocks of multiple, potentially chained and multiply recovered digital audio signals).
For a simpler system, the digital audio signals should be just as effective at delivering clock information as the WC.
