Home Forums Products Rackmount H8000 in 2U rackcase? Reply To: H8000 in 2U rackcase?
#176617
    Sure thing, I did just run both the Eclipse and H8000 for a few hours and the H8000 is noticeably warm while the Eclipse doesn’t seem to put off much heat, so you should be fine. I would still recommend doing the test to make sure the amount of heat is ok once it’s in a case, mine is in a rack with nothing surrounding it.
