Home › Forums › Products › Stompboxes › PERFORM MODE Suggestions › Reply To: PERFORM MODE Suggestions
Sorry for your frustrations and thanks for taking the time to post here.
We have discussed some options to have different text for different algorithms/presets in Perform Mode to make the UI clearer.
The restrictions for what parameters can be assigned to what footswitches was done to simplify the UI of the pedal. We may consider changing this in a future update as well.
You may find a 3-button aux switch or MIDI controller will improve your experience with the H90. This will allow you to assign your footswitch parameters however you want, and you can use the pedal in Select Mode, which will display which presets are currently being used.
I cannot provide a timeline for when either of the topics you mention may be changed in a future update, but we appreciate your input.
