Home Forums Products Rackmount My H9000 crashes a lot… is this normal? Reply To: My H9000 crashes a lot… is this normal?
#176732
ColinMuir
    Hi, thanks,
    I see it was using the previous firmware, so I updated. Fist thing I did was check a couple new algos. After ten minutes, the “alpha dial” stopped working, but only when in the parameter-edit screen. I could still use it when in all other screens.
    I ran the self-test, which reported that it ran seven tests with zero failures.
    Emailing the file to support in case there are other things which need to be looked at.
    I forgot to mention that I’m currently running the H9000 as an audio interface for my MPC one, at 44.1khz. Other than that, it’s just connected to my mixer via analog i/o.
    Regards,
    Colin
