Home Forums Products Rackmount My H9000 crashes a lot… is this normal? Reply To: My H9000 crashes a lot… is this normal?
#176757
Puppeteer
I only get consistent crashes if I try to load an algorithm (from an external source like VSIG) over the top of an algorithm that is currently being used in a chain. I can’t get other gear in the studio to sync to the H9000’s wordclock out if I’m clocking from the H9000, so tend to have the H9000 as a wordclock slave, where it works OK. I can’t really test if crashes are more prevalent using the internal clock or not.
