Home Forums Products Stompboxes Wish list from users for future updates of the H90 Reply To: Wish list from users for future updates of the H90
#177032
    Using MIDI Clock as the clock source for the H90 is a system level parameter and cannot be saved per Program/Preset.
    However, you can determine whether or not your Program/Preset uses Tempo Sync and save this setting. Example: Load a Program with a delay Preset, press the Presets and Parameters buttons together to turn Tempo Sync on, and save the Program. When you load that Program again, the delay Preset will be synced to the MIDI Clock. You can save another Program/Preset with Tempo Sync off when you do not want it to be synced.
    https://cdn.eventideaudio.com/manuals/h90/1.7.1/content/edit-modes/parameters.html#tempo-sync
