Home Forums Products Stompboxes Delay Glitches with MIDI PC changes Reply To: Delay Glitches with MIDI PC changes
#177065
I was going to suggest using another delay algorithm type that uses crossfading between delay times (Digital Delay, et al.).  But that might not have the “flavor” that you’re after.  Have you considered setting up your RJM to transmit PC over 2 different MIDI Channels?  If your base delay remains relatively consistent, you may be able to switch up your drives without affecting the H90.
