Home Forums Products Stompboxes H90 – MIDI transmit – map parameter to #cc – record parameter automation Reply To: H90 – MIDI transmit – map parameter to #cc – record parameter automation
#177095
Akum432
    Thanks for your answer! Is it:
    -a hardware limitation
    -an arbitrary decision
    -or a feature that has no value for users or priority from eventide to be implemented at this stage, or simply something that hasn’t been considered yet?
    If this is the last option, maybe I shoud add it to the Wish list from users topic? I will be very happy to record MIDI automations directly from H90 knobs to my hardware sequencer.
    With the H9, the use of an external MIDI controller was more relevant. With the new screen and workflow on the H90 I feel much less need to use an external MIDI controller. It’s pretty much the only point that forces me to use an external controller (record MIDI automations from cc) in my setup and it would be nice to get rid of it since the H90 have a MIDI output and it’s possible to assign MIDI cc to H90 knobs.
    Cheers
