Home › Forums › Products › Vsig and Preset Development › H9 Flanger Preset Advice › Reply To: H9 Flanger Preset Advice
#177122
ndeshpande
    Hi, first of all happy new year and congratulations on your H9! I apologize for this post not getting picked up sooner – this forum is designed for VSig presets, not pedal presets so your post hasn’t gotten as much visibility. In the future, I recommend you post in the Stompbox forum for H9 questions.
    You are indeed close… I think you need to tweak speed mod, mod rate, and mod source or the three rightmost knobs on the bottom row. Try using a triangle instead of a sine, try a mod rate of 1.000xSPD or maybe even 2.000xSPD, and then tweak speed mod rate from there. I don’t think you will need depth mod, but I encourage you to experiment. I’d say you can leave the top row controls mostly as-is, though I encourage you to keep tweaking… maybe try setting shape to a triangle wave as well.
    You can follow up here with questions, but I encourage you to repost this in the stompbox forum should you want more discussion on the topic to get more visibility.
