Home Forums Products Stompboxes Wish list from users for future updates of the H90 Reply To: Wish list from users for future updates of the H90
#177201
wedelich
    I would do that by utilizing Program Mix. Set Program Mix to 50/50, set your Reverse Delay Mix to 100% and map an expression pedal to the Input Gain of the Reverse Delay (-60 to 0 dB). Alternatively you could use Parallel Routing path as your “dry” signal with or without an effect.
