Home Forums Products Stompboxes Wish list from users for future updates of the H90 Reply To: Wish list from users for future updates of the H90
#177208
Adamixoye
    In Perform Mode, you should see “HS1 ON” or “HS1 OFF”. Most of the factory programs have the hot switches assigned to the 2nd page of performance parameters. Press the Perform knob twice and you should see the hot switches, and see what the UI looks like toggling them on/off. Also, the LEDs will be blue when a Hot Switch is off and red when a Hot Switch is on. You can use the momentary bypass CC message with a CC value of 63 or less to bypass the Hot Switch and 64 or greater to activate the Hot Switch. The tip in this section of the manual explains this for active/bypass, it also applies to Hot Switches. https://cdn.eventideaudio.com/manuals/h90/1.7.1/content/appendix/global.html
    Re: Hotswitch indicators, that’s helpful, but I prefer to have those main H90 switches for preset on/off (Page 1) and I had programmed an external switch for HS1 and HS2.  When I hit HS1 on and off on one particular program I care about, I see a value change on one of the Quick Knobs (since that’s how I have it programmed) but no other indicator when I’m on that first page of Perform mode.
    Thanks for helping me better understand the Momentary commands, I will look into that more.
