Home › Forums › Products › Stompboxes › Delay Glitches with MIDI PC changes › Reply To: Delay Glitches with MIDI PC changes
        January 13, 2024 at 5:32 am
        #177270
Sorry, that wasn‘t the whole answer!
As for your second issue with the delay glitches, unfortunately that is normal behavior with these algorithms. Any time the delay time or heads change, there will be a delay warp sound. That noise is a byproduct of the effect. Sorry. You could try using a Hotswitch instead of loading another preset. You can have 2 subdivisions using the different heads, and the Hotswitch can change the level of each head. Also, our developers are aware that some customers do not like this behavior, so they may look at changing it in the future.
