Home › Forums › Products › Stompboxes › ADSR (Sustain, Release … ) with Synths on H90 › Reply To: ADSR (Sustain, Release … ) with Synths on H90
Something like this might be one more way to get started. It uses the same general concepts, but with the Omnipressor mode in DynaVerb as the “envelope”. In Series with a mono-configured PolySynth – all 100% wet.
https://patchstorage.com/attack-bass-tbrock-303/
This next one has some dry mixed in (which you can dial back). The idea here was to use HotSawz for its fast attack, and PolySynth for a slower attack, with the two synths in parallel. Bypass one or the other, if it suits your purpose.
https://patchstorage.com/mono-y-mono-sawsquare/
There is a lot of tweaking built into both of these Programs with [P] [A] HotKnobs, HotSwitches, Performance controls, and dual expression pedals. I’m thinking it might be easiest of all to dial around parameters using some existing Programs, then Save what you like afterwards.
