Home Forums Products Stompboxes H90 one button looper MIDI control issues Reply To: H90 one button looper MIDI control issues
#177500
StrolloSound
    Hello
    Following up with an attempt to use a KM SoftStep 2 MIDI controller to do the same thing:
    1 Button Looper to activate the same series of events as a hot switch on board the H90 –
    one press = REC, PLAY, DUB
    two press = Stopped
    hold = EMPTY
    Firstly, is this possible with one button on an external MIDI foot controller ?
    Or can you only assign several buttons to do the individual tasks?
    (If so, I do not see DUB as one of those options)
    Secondly, The Soft Step is assigned to send 127 press and 0 release,
    is there any other way I should program the button to simulate the order of events of the 1 button Looper?
    Lastly if I had to go with a non MIDI external 3 button AUX external foot switch plugged in to an EXP jack
    to make a direct clone of the onboard P, A & B switches  what would you recommend?
    Thank You!
