Home Forums Products Stompboxes H90 – Best 3 way footswitch Reply To: H90 – Best 3 way footswitch
#177578
StrolloSound
Trying to use a Keith McMillan Soft Step 2  as a MIDI foot controller
and having issues making CC messages work with the Looper
(Thankfully PC messages are working fine for loading programs on the H90)
First I tried to assign a single button to use as a remote 1 Button Looper
but realized that you are supposed to assign 3 buttons to the Lopper controls
REC , PLAY , STOP and that the Dub happens when you hit REC again and EMPTY would need its own button if needed.
I Made sure I had all the assignments set properly on the H90
and it initially started to work but soon became unresponsive
I Made sure that the CC numbers were correct on both devices
and made sure the buttons were sending a value of 127 when pressed and 0 when released
