Home Forums Products Stompboxes H90 1.7.6 update issue Reply To: H90 1.7.6 update issue
#177747
StrolloSound
    a few questions about the new  update  –
    I see in Global where you can set the new bypass feature  to A&B
    and I was able to make a hot switch 1 Bypass the user Preset in the A slot
    can you set another switch to the preset in the  B slot?
    Secondly – I am having some problems getting user Preset parameters to save properly
    what is the best protocol once you make a change in a preset that you want to be permanent?
    I have been saving the Preset first then the Program both by overwriting when given the option
    Unfortunately this still seems to create a duplicate in the user Presets as seen in the list in the Control app.
