Home Forums Products Stompboxes Wish list from users for future updates of the H90 Reply To: Wish list from users for future updates of the H90
#177916
fiddlercrabseason
    Adding ‘phase adjust’ and ‘phase reset’ parameters for any of the modulation/shape/etc. parameters.  Example use cases:
    1) 2X Harmadillo presets (or TremVerb, et al), parallel routing, both 1/4 note rate, preset B “xxx.x degrees” out of phase with preset A.  Currently, with both set to 1/4 note rate, re-loading the program loads both in sync.
    2) conversely, if I want to modulate the rate of either preset A or B, the only way to reset the phase to get them both in sync is to re-load the program.
    3) would also open up the ability to modulate the phase and/or trigger the phase reset via expression, MIDI, CV.
    If I’m unaware of, or have overlooked, a way to do this with existing algos, please let me know.
