Home Forums Products Stompboxes H90 with Helix floor routing question Reply To: H90 with Helix floor routing question
#177994
joecozzi
    Each Path in Dual mode can be mono or stereo depending on which outputs are connected. For example, if you connect a cable to Outs 1&2, Path 1 will function in stereo. If you only connect Out 1, it will function in mono. The same with Path 2 using 3&4.
