Home Forums Products Stompboxes Wish list from users for future updates of the H90 Reply To: Wish list from users for future updates of the H90
#178001
    Bear with me: A PERFORM Mode “HotSwitch” to toggle between two separate ranges of parameter mapping.
    • No doubt tied to the [P] switch, selected under that display column, using the [P] LED button.
    • Named something like ALT, or whatever fits.  Debatable usefulness for an ALT (M).
    • In the Parameter Mapping popup, a toggle to set START & END ranges in two distinct sets  / pages (BASE & ALT – ALT1 & ALT2, etc.).
    1. Example: Two switchable ranges for Mod Speed and Mod Depth, tied to a HotKnob.
    2. Example: Instant reverse on an expression pedal mapping over, say, a pair of Delay times.
    3. Example: Two defined ranges of an incoming MIDI CC over a particular parameter or three.
    4. Example: Lighter & heavier MIX over an effect; different START point & the same END point for a given pedal travel.
    My main thought here was a single expression pedal (or two) performing ‘double-duty’.  Work the pedal, press a (ALT) Perform switch, and it ‘mutates’ into controlling another range of that pre-assigned set of parameter mappings. But bonus points for switchable control sources under the same parameter mapping ‘toggle’ paging.
