Home Forums Products Stompboxes H90 latency Program Change Reply To: H90 latency Program Change
#178077
Vavoom
    Recently picked up the H90 (new) and after programming with Morningstar MC6PRO, I am seeing/hearing the same latency when switching programs.
    It is more apparent when using a midi switcher and going from PC change to PC change.  Very apparent.
    In a live situation, this could be problematic. I’m getting about the same delay as the video.  The video pretty much shows the delay…and you can easily hear it.  I would guess it’s about around 700 ms.  There has to be a fix. I had a delay like this once with a midi switcher and an adjustment to a time parameter on the midi switcher fixed it, but that was 15 years ago.
