Home › Forums › Products › Stompboxes › Getting a Script Phase 90 Preset from the H90 › Reply To: Getting a Script Phase 90 Preset from the H90
#178090
    If you’re going for that Phase 90 mildness, simpler may be better (the Phaser algo).  I have an ancient Program uploaded, but it’s paired with Flanger in Series for some additional complexity.  Maybe you can try some settings like this (on the right side).
    Not much to it.  4 Stages, Positive Type, 50:50 Depth, Triangle Shape.  If I recall, Speed would be accurate in the range of around 0.10 – 8.25 Hz.  Zero out the remaining parameters.
    Gray-Orange-Box-MiXeR-63c43c5a37d1d-1024x583
    Not much to it.  Back off the Intensity, 4 Stages (or 2 Stages for a 45), Positive Type.  50:50 Depth, Triangle Shape.  If I recall, Speed would be accurate in the range of around 0.10 – 8.25 Hz.  Tie it to a HoKnob adjustment.  Zero out the remaining parameters.
    <span style=”font-size: inherit;”>For added complexity & cancellations, copy Preset A into Preset B – in Series or Parallel – then very slightly vary the Intensity, Speed, Depth. Come too think of it, TriceraChorus has a great stereo phaser {SWIRL ON}, but I don’t hear it as being in the Phase 90 vein</span>
    <span style=”font-size: inherit;”>I imagine you can can also close with Instant Phaser.  It kind of has its own thing going on, but it’s worth a shot.  In fact, I’m inspired now to mix degrees of Phaser & Instant Phaser together, and see what pops up.</span>
