Home › Forums › Products › Eurorack Modules › Misha Sequencer options › Reply To: Misha Sequencer options
Hello-
Glad you are enjoying the unit
Actually if I understand you correctly, the functionality you request is already in there, if you can split that clock and send it simultaneously to two places: clock in and X t/g In.
With those two cables connected, then go to settings/ cv in x:
range: make sure your range matches whatever is sending the clock
linking: unlinked (T)
trigger function: key mapping
Trigger mapping:
num 1:
type: chords
action: random
No other settings matter here
if you really want one chord per clock then you really should go into setup/clocking/ext clock PPQ and set to 1
I just tried this and it seems to work
you could also have it increment/decrement along the 9 chords
In that CV In menu you will see also you have other ways of varying the sequence
Let me know how it goes for you
Leon
