Home Forums Products Eurorack Modules Misha Sequencer options Reply To: Misha Sequencer options
#178180
samchillian
    Well I’d recommend checking out the options in that key mapping menu- all those modes of playback are in there.
    However in this case I think you’d need to connect another cable.  You’d connect the clock to X t/g in as before and then connecting X Cv in to your joystick should allow you to pick one of 11 different functions depending on its position
    For this usage you’d want
    linking: linking (T, CV)
    trigger function: key mapping
    Trigger mapping:
    num 1: prime
    num 2: retro
    etc
    anyway, experiment and see how it works for you
    Leon
