Home Forums Products Rackmount Your user experience with the H9000 Reply To: Your user experience with the H9000
#178342
ColinMuir
    I wanted the h9000 full UI model since I believe it’s slightly more future proof.
    The downside is there seems to be an attitude that if it it doesn’t work on the native UI, because buggy, then no matter because you can just use emote, which is perhaps more ambitiously supported.
    Other than the UI bugs, I think H9000 is so versatile that it can fit into any studio. The fact that I can connect more ADDA via adat, aes/ebu, etc, and also run it as a USB audio interface, and make connections between any i/o is just wonderful.
    Also it just sounds absolutely freeking awesome.
