Home › Forums › Products › Rackmount › Bug report? ADAT routing mixes up ch1/ch2 etc › Reply To: Bug report? ADAT routing mixes up ch1/ch2 etc
February 18, 2024 at 9:13 pm
#178352
What sampling rate are you using. If it’s above 48kHz, the channel count will be halved, and how those are duplexed may affect what channel numbers the signal appears on.
See if you get the same issue at 48kHz. They certainly work as expected on my H9000 with my RME UFX.
