Home Forums Products Rackmount Axe FX Delay Algo Replication Reply To: Axe FX Delay Algo Replication
#178365
ndeshpande
    This is something you could wire up yourself in VSIG, and the video gives you the added benefit of showing you what to wire up where and with what parameters. Some combination of compressor, multidelay, and stereomixer modules should get you there. I’ll give you the warning now that if you’re wiring in lots of feedback amongst two parallel delay lines, be very very very careful – the energy can oscillate very quickly if you’re not careful and don’t know how to prevent runaway feedback. I encourage you to put in a button to mute the output sound ASAP, or clear the delay lines and reset the feedback to zero, should you need to quickly mute the output.
