Home Forums Products Rackmount Feature request – metering “presets” Reply To: Feature request – metering “presets”
#178380
    In Emote, you can select Window > Meter Bridge and this will allow you to view groups of 8 meters at a time in the application UI. These selections will also populate the meters that are displayed on the front panel. https://cdn.eventideaudio.com/manuals/h9000/2.0/content/emote/overview.html#menu-bar
    I’m not sure if we’d be able to implement something on the front panel that changes all meters at once. If you’d like to use the front panel for this, you can change them one at a time as this currently works fine.
