Home Forums Products Rackmount DB 25 input to XLR 1,2 output? Reply To: DB 25 input to XLR 1,2 output?
#178457
bsfreq
    You don’t mention which device, so I assume you’re asking about the H9000?
    You also don’t mention which DB-25 input, analog or AES/EBU.
    Yes, you can route signals from any of the analog inputs via the DB-25 connector, as well as from any of the AES/EBU inputs using the DB-25 connector, to the XLR analog outputs.
    “Note that the rear panel XLR analog connectors are a duplicate “mult” of channels 1-2 of the eight- channel analog DB-25 connectors.” So signals are shared between XLR in 1-2 and analog DB-25 in 1-2. Same goes with outputs.
    In case you’re talking about AES/EBU, there’s only this limitation: “You can only use one digital audio protocol at any given time. This will be determined in your “Digital Audio Mode” setup.”
