Home Forums Products Stompboxes H90 Insert Bypass ? Reply To: H90 Insert Bypass ?
#178553
    You need to use AB Only bypass mode if you’d like the inserts to remain active when the Program is bypassed. Tails/Spillover will still work with this setting.
    Note there is also specific Insert active/bypass controls that can be mapped to MIDI/aux switch: https://cdn.eventideaudio.com/manuals/h90/1.7.5/content/appendix/global.html
    You can also bypass either insert using Perform Mode.
