Home Forums Products Stompboxes H90 Insert Bypass ? Reply To: H90 Insert Bypass ?
#178562
Herr Mosa
Thanks for that! I have already found Insert On Off in performance mode.
What I would like, however, would be the option of simply switching the insert on and off with the P on/off. This is about the opposite of what the AB Only function features, if I understand correctly.
Unfortunately, I only have two aux switches, which are assigned to Programme/Performance Mode and Tuner on Off. So I would be missing a third aux switch and it would be a bit more of a tap dance.
