Home › Forums › Products › Stompboxes › H90 Insert Bypass ? › Reply To: H90 Insert Bypass ?
#178566
joecozzi
    I have my H90 in DSP Bypass mode and I can get it to do what you want, allow the insert audio through when active and shut it off when the H90 is bypassed. Are you sure you’re using IN/OUT 3 to connect your external pedal as an insert?
