Home › Forums › Products › Stompboxes › Wish list from users for future updates of the H90 › Reply To: Wish list from users for future updates of the H90
#178661
    Kill Dry refers to how the mix parameters of the Programs/Presets works; it removes the dry signal. It sounds like what you are describing is a Wet/Dry configuration: https://cdn.eventideaudio.com/manuals/h90/1.7.5/content/setup/wet-dry.html
    The H90 can be used in a wet/dry setup (as seen above) or a typical stereo setup as you are doing already. It cannot do both. Sorry, I’m not sure if we will consider this request since both setups can already be accomplished.
